Darren
Hi
I have a thermally controlled 120mm fan. It's an Antec 120mm Smartcool.
It has a thermister which protrudes about 2.5cm/1" from the the bearing, on
a slight angle into the case.
It spins at about 1100rpm max. It's too far from the heat source, 'miles
away' and I need it to spin to its max of about 2000rpm.
I was thinking about replacing it with a resistor/variable resistor but
wasn't sure of the resistance required.
What do you think? Any resistance? Boom boom.
Darren
Darren
