John Devereux
I have a metal-bodied LED like this one:
<http://jp.hamamatsu.com/products/sensor-ssd/pd150/pd157/L9437/index_en.html>.
I would like to heatsink it via the PCB groundplane. Also it needs to
be fixed very solidly to minimise movement under vibration. I could
solder it down but would be worried about temperature.
I don't need to isolate the case, but I don't want to use that
electrically conductive silver paste either since will likely short
out the anode lead.
Any suggestions?
The "thermal" epoxy compounds I found seem to be designed with filler
particles that ensure insulation, but would limit heat transfer. I
guess normal epoxy would work, or maybe cyanoacrylate (low viscosity
so get thinner layer)?
out the anode lead.
Any suggestions?
