I'm having a PSU board laid out at the moment that is conducting some
reasonable current (8A). The ground connections have been made to the
ground plane with what i believe is called thermal relief - there
isn't a full ring of copper around the hole to connect it to the
ground plane, instead there are 4 thin tracks - to help when soldering
the thing together. I have a couple of questions about this.
1.) Does anyone have experience of soldering devices in without this
thermal relief? If its not much worse then this is surely the way to
go to ensure enough current handling / low resistance to ground.
2.) If its a royal pain to solder is there a better alternative - for
example thickening one of the spurs to the thickness of a track.
Andrew
Andrew
