I have a Theradyne treadmill (discontinued, not supported). When turned on it goes to an E5 error, which is associated with the incline motor.
I can get the incline motor to run all the way up and all the way down, manually connecting it to power, so I think it's fine. I can also get the treadmill to run for a few seconds at a time, sometimes, so I think the belt motor and PWM controller are fine. I think the problem lies in the "top" control board, which has the input/output switches, display LCDs, etc. There seems to be some history of problems with these machines.
Anyway: I'm trying to figure out if I can ignore the top board: for example, the incline motor is simple AC, so I can just put an up/down switch on it and run it manually.
I'm less clear on what I can do with the PWM belt motor. There's a separate PWM motor controller... would that typically be controlled by a digital signal from the top board? There's about 8 wires between the two, I think, and several are power/ground, so I guess it could be some series signal... there aren't a lot of IC's on the PWM controller. I'm including a pic.
I'm competent at basic electronics, but get lost in the weeds quickly with deeper stuff: I've only got a superficial knowledge of digital electronics, for example, and I'm not strong at troubleshooting power supplies, etc. But I'm a good solderer...
One of the resistors on the PWM controller had a broken lead that I found, I tested and the resistor seemed fine so I carefully extended the lead and got it all reconnected.
There's supposed to be some magic way of getting it to do a "calibrate", but despite a LOT of searching (I finally got a copy of the manual: it's not in there) I'm giving up. I can occasionally force it into calibrate mode maybe sorta, but I can never tell what I've done that causes it (it's typically after I've diconnected/reconnected leads maybe 100 times, grounded various terminals, etc). I've never even come close to being able to do it twice in a row, and it's never successfully completed a calibration anyway... Which is why I'm thinking of ditching the entire high-level control circuitry.
Thanks for any help.
Keith
Keith
