Hi.
I'm thinking of way of making a really tiny 240vac or 240vdc to 12vdc power supply. I need it to be less than 20x20x20mm (yeah i know ) if it can be done smaller it would be even better. i've searched for transformers but i can't seem to find a transformer that small on digikey.
The power supply will supply a circuit of picaxe (08m2 smd) or pic (haven't figured that out yet) that will drive an irf740 with variable duty cycle (adjusted by a potentiometer) at 100-600hz. and a resistor/zener to give the picaxe the 5v. So maybe a switching voltage regulator circuit without the actual controller? Like an oscillator fet choke capacitor circuit that will work on a fixed freq?
I have worked before with smd components like SOT-23 fets and the tiny resistors/capacitors that are less than 1mm long so you can design a circuit that uses the smallest components available.
Thanks.
Thanks.
