The phase noise of the MCU generated signals
  • Thread starter Vladimir Vassilevsky
  • Start date
V
Hello All,
Sometimes it would be handy to use MCU timer outputs as clock sources.
However I haven't seen any information regarding the phase noise of the
MCU generated clocks. Assuming the input clock signal is ideal, what
level of the phase noise can we expect from an MCU timer generated
signals? Would the result be different for the MCUs with or without the
internal PLL? Could we assume that the phase noise equals to the
internal noise divided by the slew rate? Then what is the ballpark of
the internal noise?
I guess the same considerations apply to the FPGA generated clocks as well.
DSP and Mixed Signal Design Consultant
http://www.abvolt.com
Joerg
Vladimir said:
Hello All,
the internal noise?
Ok, you've got the HW pointers already now. Be careful with the source
itself. Often uCs use what marketeers call digital frequency loop or
similar. In order to generate the more odd ratios they skip a cycle once
in a while. That can make for nasty surprises when this comes out of the
timer. So employing the typical watch crystal -> high frequency method
may not work for you.
MooseFET
Hello All,
the internal noise?
The noise inside the chip of the SiLabs F120 appears to be about 2.5V/
2000. I base this on the performance of their internal 12 bit ADC.
I's bet that the actual number varies all over the place from location
to location inside the chip.
Do you consider systematic variations to be part of the "jitter" of
the PLL. If you run the F120 on a 22MHz crystal than then multiply up
to 88MHz in the PLL, I'd bet there would be a fairly obvious 4 cycle
long pattern in the noise of the 88MHz
In the FPGA case, you can make sure that the output is synced up to
the clock before going to a pin. In some MCU designs, the counter
signal will go through a lot of logic on the way to the actual pin.
At each stage more noise gets added in.
Joerg
John said:
Yup. When you see a lot of jitter, check the power supplies.
And, especially when working on chips with bipolar structures in there,
turn off the cell phone :)
Random notes:
We've gotten well below 50 ps RMS jitter out of Spartans doing lots of
clocked and combinational stuff to signals. But it wasn't obvious or
easy.
A Spartan3 internally clock-doubling a 40 MHz clock produces an 80 MHz
lopsided (bimodal) square wave that has, in effect, about 40 ps RMS of
deterministic jitter.
Ordinary HC-type gates can propagate periodic signals with ballpark 10
ps RMS jitter, so effective noise must be ballpark a few millivolts
RMS. The worst thing is prop delay vs temperature, which creates delay
"wander." A uP may add a bunch of ground bounce noise as it crunches
instructions.
You can always clean up a timer's output by resynchronizing with an
external d-flop.
I'd expect any high-ratio clock multiplier PLL to create a lot of
jitter, FPGA or uP.
What sort of numbers do you need? Things like 100 ps RMS should be
easy as long as a PLL isn't multiplying much.
John
the xilinx fpgas are delay locked loop so it will jump between
discrete
step of 50ps?
looking at all the talk about sso in fpgas I'm guessing that supply
noise and
other activity on outputs could have a lot of effect on jitter
-Lasse
V
easy.
instructions.
external d-flop.
jitter, FPGA or uP.
On the BlackFin DSP, the jitter of the timer generated signals appears
to be about 150...200ps rms (measured). This is without any activity on
the bus or I/O; the power supplies and the layout are OK. The jitter is
clearly correlated with the internal activities of the DSP.
BTW, I recall the old book on the synthesizers where they claimed that
the ordinary 74xx gates are quite low noise: something like
-140...150dbc. The schmidt gates are noisier then the simple gates. But
the main rule is never run unrelated frequencies through one logic IC:
there will be the intermodulation products with the levels -40...-60dB
all the way.
MooseFET
all the way.
When you use divider chipss, the LSB has low timing jitter but all of
the higher ones are modulated by the lower bits.
74HCxx chips can be very low noise if you keep the supplies quiet.
Grouping together chips that contain signals that won't mess with each
other and then providing local regulation of the supplies of the
groups worked very well to keep the noise low. The surface mount
little regulators don't need heat sinking so it doesn't add much to
the size of the PCB.
Joerg
Oh yeah. We used those extensively for stuff like driving the LO side of
mixers is very noise-critical Doppler receivers in the late 80's.
No LDO in this here office. I do not trust them unless I roll my own.
A "capacitor multiplier" (follower with cap from base to GND and
resistor to incoming VCC) usually suffices.
K
krw
The edges of alternate cycles of our 80 MHz clock seem to be displaced
in time, but don't "jump around". The clock is internally doubled from
40 MHz. It's similar to the wobble you'd see with a classic
tuned-circuit frequency doubler. I suspect they are using taps on a
delay line to do the doubling.
Right, the Xilinx DCMs use DLLs to do everything.
Yup, everything talks to everything on-chip. The clock nets seem
stiffer than long signal routing paths. Maybe.
They'd better be. ;-)
MooseFET
I assume you mean:
FZT2222 or equi.
! \ /e
GND
The down side is that the voltage out depends on temperature.
The good old LM7805 type regulators can be had in surface mount. If
you give them about 3V of head room they have good power supply
rejection.
In both the LM7805 and the 2n2222 like cases, I have found that an
impedance in the incoming power line still helps. An RF bead will eat
any RF that is trying to come down the path. Harmonics of your other
switching signals can be trouble makers.
BTW: You will notice if you search what I said carefully that the term
LDO doesn't appear. I find them to be dreadful also. The fact that
they require that their load appear slightly resistive over a band of
frequencies is sloppy design in my opinion.
Joerg
MooseFET said:
I assume you mean:
FZT2222 or equi.
! \ /e
GND
Yes, but so does the chip timing itself because that'll heat up, too. In
most of my designs things are paired, quad'ed or otherwise matched up
anyhow. Other times it's servoed. This takes temperature out of the
equation. But none of those tricks can get rid of phase noise once it's
in there. So the supplies have to be squeaky clean.
rejection.
And very nice de-icing behavior :)
any RF that is trying to come down the path. ...
Yes. Or a small resistor.
... Harmonics of your other switching signals can be trouble makers.
That's what the above is for ;-)
Unless you roll your own. Seen too much grief with LDO chips. Way too
much, all the way up to uncovering non-documented behavior. When you
hear a team of engineers at a major semiconductor mfg shuffle tons of
paper at the other end of the phone line and then one of them exclaims
"Oh dang!" then the end of the rope is near.
MooseFET
MooseFET wrote:
[... supply voltage and phase noise ....]
In one example designed by someone I work with, the timing wasn't
servoed but it was measured as part of a continuous self calibration.
The product was mostly a period measurement. Every second pulse
through the important path was a calibration one. The circuit turned
a fraction of a clock cycle into an analog voltage that went to an
ADC. The calibration pulses checked the two ends of the span of the
ADC so that it could be kept as 4096 meant a full cycle.
The current isn't usually all that much in the parts where the phase
noise really matters. The display and the RS-232 and the network and
all that other stuff can be run on a switcher that uses hit and miss
regulation with a chattering relay.
Yes but that doesn't look nearly as scientific. Part of the job is to
keep the masses mystified :>
A double yes.
In the roll your own, you are free to not make it need a resistive
load and I assume this is what you do. You can also fly the control
circuit at the same AC voltage as the power input to do a feed
forwards.
! ! e\ / !
! ! Vcc Control circuit +!-----
+------! Gnd with remote -!-----
! ! sense ! !
If the control circuit doesn't make a lag over about 45 degrees, the
load can be a pure capacitance without trouble. I usually would put a
small resistor in series with the emitter or source of the pass
device. This way, the gm of that section is better known.
I had a phone call like that with someone at Linear a while back on a
switcher chip. The LT1246 switcher has a bug. If you pull the Vc pin
all the way to ground, the output can do random stuff. It adds a
diode to the design to prevent this. Kludging the diode in on the
prototype fixed the problem. The guy at Linear assured me that they
would fix the datasheet. I haven't checked that they did.
Joerg
John said:
We epoxy pin-fin heat sinks to some of the larger parts, and put dabs
of colored epoxy on some of the smaller ones.
Do you sprinkle some pixie dust on the epoxy for the smaller parts?
Joerg
Chris said:
A while ago I suggested the Analog Devices ADP3300 and ADP3330 but you said
they were too expensive. Anyway they haven't oscillated in my experience
so far.
The 3300 is ok in price but 50mA is a bit wimpy. The 3330 is too pricey
for most of my apps (but not for all of them).
The LM833 style reminds me of a consulting job way back when. Noise, the
usual. Caused by some RAM bank power surges and, like most of the time,
I was called in after the fact. Layouts all done, no chance to do any
serious filtering. Luckily they had placed small current sense resistors
so technicians could measure the current intakes. Plus, yeehaw, a few
free bus connector pins. So I current-sensed the nasty stuff and fed it
back into the backplane inverted. Loop stability wasn't exactly trivial
though because some of it migrated into the offending board rail again.
When presenting all that at the afternoon meeting the reaction was utter
disgust. "Yikes, that's ugly! I don't think it'll work." ... "Ahm, I
reworked it into one system, check it out." ... They did. Noise gone.
That cinched it.
MooseFET
Feedforward will sure not help AC load regulation; the series R makes
it worse. Feedback onto the output node helps everything.
I have seen lots of bad or marginal ideas from Wenzel. If you are
going to add transistors and losses in the name of improving PSRR, you
are likely to do a lot better cleaning up the input to the LM78XX than
cleaning up the output.
--+------ ------+-----! LM78XX !----+---
! \ / e ! -------- !
-/\/\---+----!!--+--GND---- GND
Nowadays you can put a ton of ceramic and polymer aluminum bypassing
on a rail, so all the feedback thing has to do is stomp the lower
frequency noise. That shouldn't be hard to stabilize.
For low frequency stuff, you can use the LM78XX as the pass element
and wiggle its ground wire a bit to remove any low frequency AC at the
load. If you keep the corner frequency of the loop enclosing the
LM78XX below about 100KHz, you can ignore its phase shift.
MooseFET
Certainly PSRR is better fixed by cleaning up the supply at the input of the
regulator, but that will not help the noise of the regulator itself.
                             -------->  --+------     ------+-----! LM78XX !----+---
That sounds like it should work as long as there isn't a lot of decoupling
on the output of the regulator.  Where you need a lot of decoupling at the
output of the regulator I suspect it could get tricky.
The more bypass on the output of the regulator, the lower the gain
crossover of the loop needs to be. On the other hand, the bypassing
also lowers the frequency above which the capacitors eat up all the
noise.
