Peter
A lot was said about this c. 2005 but the whole discussion seems to
have died down.
Here in the UK, most people have now moved to lead free solder. A lot
used the Control & Monitoring Equipment ROHS exemption, which is valid
till 2017 and this protects you fine if you sell direct to many small
customers, but if you have big customers you can't use it because most
big firm customers are bullying their supplier base with surveys
demanding a confirmation of total compliance on ROHS & REACH...
At work we tested about 30 hand solders and all but two were absolute
crap. I cannot see who could use the others - except maybe with a
*very* hot iron e.g. 400C+ and zero quality control. The two which
worked both contained silver (SAC solder). One was GBP 45/0.5kg (5x
more than normal solder) and the other, which is actually pretty good,
is GBP 65 (from Almit in Japan). Per product, the cost of the hand
solder is negligible however. Neither of the two flows well; they do
good joints but basically the solders stays where you put it. It
doesn't like to flow into a gap e.g. if soldering a TO220-style
package onto a PCB by the tab on it.
But it is in SMT reflow soldering that the whisker troubles happened.
I read the Swatch story; obviously they found a solution eventually.
I wonder if perhaps several factors helped:
1) The silver stabilises the solder and stops whisker forming. I found
most reflow soldering is done with SAC solder, despite its hugely
bigger cost.
2) The industry stopped the quest towards ever finer TSOP package pin
spacing. We use 0.65mm pitch which is probably OK. The really dense
stuff went to BGA which is very well spaced out.
3) Much electronics is consumer stuff and nobody gives a **** if it
packs up after a few years...
The military retain their exemption for ever, presumably for a good
reason.
The problem I have is that out products routinely run for 20 years, in
cabinets, at an elevated temp, perhaps +50C.
Any views?
have died down.
bigger cost.
reason.
Any views?
