the blades are corrected this morning --- RFC
developer
http://www.web7days.com/hydro/windmill2/tn/PICT00018.JPG.html
the 16 blades windmill actually spin itself when there is light breeze while
the three blades does not spin at all even though the center piece is a lot
heavier then the blades windmill that I build with aluminium.
RFC
http://www.web7days.com/hydro/windmill/ 16 blades
http://www.web7days.com/hydro/windmill2/ 3 blades
solar power arm board development team
http://arm.web7days.com arm board
http://www.web7days.com/led solar power control center
http://www.web7days.com/farm farming
Morten
I have no doubt that the 16 blade will spin in a slight breeze, but you
still _need_ the right blade profile (as mentioned in previous messages) to
do this effiently.
You wan't to extract as much energy from the air as possible and the better
the blades the more energy you can extract.
If I remember correctly the energy in the airstream is such that you will
get about 2kW with a blade span of about 3m, ie a radius of 1.5m at a
40-50Km winds, so to get any usefull energy at lower speeds (and less
efficient blade profiles) will be impossible.
How much energy do you need, are you planning for batteries or is the load
(was it a telly?) going to be driven directly by the alternator?
What's your average windspeed at the location where the windmill is going to
be located?
/Morten
developer
do this effiently.
no, in holland and greece, those big windmills does not even have real blade
profile at all.
that is why I corrected three blades and I can extend to 9 inches more.
the DC motor is being using and not car alternator which require 8000 rpm.
be located?
I hoisted to the roof only when I can achieve the next generation of my
design. everything will be aluminium except the three blades.
