Greetings!
I have seen multiple videos of how to test a microwave diode with a 9V battery using a multimeter. But, I don't have a multimeter. However, I do have a 9V tester, which I think can be used. But, I want to make sure this is true before I think I have a good diode.
According to the videos, when I use a multimeter, if I place a diode between a 9V battery and the multimeter while set to display volts, I should get about 6.3-6.6 volts. I have a 9V tester, and if I set the diode between the 9V battery and the tester, I get 6.6 volts. If I take the diode out, I get 9.3 volts. So, is this test good? Thanks for your help.
josé
josé
