Hi all
I am looking into designing a test jig that will be used to test populated PCBs off a production line.
The PCBs will be microcontroller based with I/O lines connected to LEDs, buzzers, some analogue circuitry too.
I need to be able to test each PCB circuit functionality using a test rig abd indicate if it has passed or failed. Also at what point it failed.
My questions are
1. I think i need a a means of connecting the PCB to my jig. Do you think a pogo pin system where the PCB is placed a good idea.
2. My test routines will be using the same microcontroller. But i am not sure how test each bit of the circuit. For example the LEDs i could use a light sensor to detect if it has been lit or could i use an A/D input?
Similarly how will i test the buzzer circuit.
3. Same as q2 for power supplies within the PCB ie 3V3, 12V etc. Checking cirrect crystal operation.
I presume i will need a few test points around the circuitry i am testing, hence using the pogo pin method of contact.
I am only after a few guidelines on the best way to approach this.
Thanks in advance.
My questions are
Thanks in advance.
