This is aimed at reducing the unnecessary battery drain during presence of external supply.
i am trying to build a circuit that powers a device that operate at 3.3v to 5v max of 2A. It contains a battery. I would like to isolate the battery from supplying current to the load in presence of External supply and to switch over from supply to battery power during power cut. The problem I could face is that once the External power is cut it takes a delay to switch from Supply to Battery which could make the device switch off for an instinct causing loss of data. I prefer to maintain the Current for a duration of at least 2 seconds after power cut so that the switching from Supply to Battery could occur without any fluctuation. I had an idea of using a Capacitor but its size may be huge(my assumption). I request you to suggest me an solution to my problem.
Note:
Energy Holding time - Minimum 2 Seconds.
Voltage - 3.3V to 5V
Curretn - 2A
Note:
Curretn - 2A
