Russ said:
Mike,
Do you think any model will work or should I buy one of the expensive ones?
They have them from around $40.00 and up. It would be cool when working on
a pinball if I could point my thermal laser probe at all of the transistors
and find the one that isn't working.
Russ
There are a bunch of issues.
The spot/distance ratio is critical. At the distance of measurement,
the spot size has to be small enough to measure just the thing you want.
But as it gets smaller, you have trouble aiming it. Even with a laser,
there's an offset that causes parallex error. The sense spot can't be
in the same place as the laser spot at all distances.
Emissivity relates to how well a particular material and surface
treatment radiates relative to a black body. Most cheapo units are
fixed at .95. More expensive ones have a calibration adjustment, but
that won't help if you don't know what to set it at.
Point it at a shiny aluminum heat sink and your reading won't be
anywhere near accurate. It's a relative measurement for similar
materials only.
In most cases, you have no idea what 'normal' temperature is.
You can't tell if the problem is the device, a loose mounting bolt,
something else causing the overheat.
"back in the day" story alert....
Once tried to measure the temperature of a circuit board with an early
IR video scanner. Result was dismal because of the widly varying
emissivities.
Sprayed the whole board with spray-on foot powder.
Worked great cause it normalized emissivity.
Problem was that I couldn't wash the stuff of when I was done.
Ended up scrapping the board...very expensive temperature test.
Bottom line,
I use mine more to check the temperature of my coffee when I nuke it
prior to pouring it into the thermos. Fun toy, but relatively little
used in electronic diagnostics.
mike
Return address is VALID but some sites block emails
with links. Delete this sig when replying.
Wanted, PCMCIA SCSI Card for HP m820 CDRW.
FS 500MHz Tek DSOscilloscope TDS540 Make Offer
Wanted, 12.1" LCD for Gateway Solo 5300. Samsung LT121SU-121
Bunch of stuff For Sale and Wanted at the link below.
MAKE THE OBVIOUS CHANGES TO THE LINK
ht<removethis>tp://
www.geocities.com/SiliconValley/Monitor/4710/
