Hello,
Brand new to the Forum and would appreciate any help with my scope issue.
I recently purchased a Tektronix TDS540 Oscilloscope from EBay and I am aware of the capacitor issues. I have the capacitors in hand but have not replaced them yet. I have not powered the unit on yet because I wanted to perform a visual inspection of the boards for capacitor leakage / corrosion, etc. first. It seems to be fairly clean but will check and clean as necessary.
I found a burnt surface mount resistor on the DRAM Processor / Display board and cannot read the reference # (Rxxxx) or tell its value. I have enclosed pictures of its location on the board. It is in the front part of the board near U171, U172, C62, C1225
I do have the Service Manual but no schematic and have not performed any troubleshooting at this time.
I would like to replace this resistor, repair the burnt board and replace the capacitors, clean board before powering up the unit. I would think this is a multi layer board and hope other traces are not damaged.
Need help determining the resistor value and what may have caused this. Hopefully someone may have seen this before.
DRAM Processor / Display Board - G92-0658-02 (Label # 671-1477-01)
Thanks for the help, Scott
