Tektronix Data Generator.
Has options 02 and 1R
This Data Generator has very low hours, is in very good condition and perfect working condition.
It is a 36 channel with the Rack Mount option as well.
These are currently selling for over $12,000.00.
Features and specifications of the Tektronix DG2020 Pattern Generator include:
• 200 Mbits/s maximum output data rate - Up to 64 K words/channel data word length
• Up to 36 output channels in 12-channel incrememnts
• Up to 36 independent variable delay output (20 ns, 100 ps minimum resolution)
• Output level
• Flexible sequence control and data jump
• Try-state control
• Powerful and easy-to-use data built-in editor
• Data import from various instrument and other source
Output Data:
• Data Rate: -0.1 bps to 200 Mb/s
• Sampling rate: 0.1 Hz to 200 MHz
• Resolution: 4 digits
• Period jitter: <50 ps RMS (at 200 MHz)
• Accuracy: PLL On, ±50 ppm; PLL Off, ±3%
• Data Depth: -64 K to 64 K word (1 increment)
• Data Width -12 bits (std), 24 or 36 bits (optional)
Sequencer
• Max number of lines: 4096
• Max data repeats per line: 65536 or infinite
• Max number of jumps per sequence: 4096
AUXILIARY INPUT
Clock - SMB connector (rear)
• Threshold level: VIH>0.7 V, VIL<0.3 V
• Maximum input voltage: ±2 V
• Frequency: DC to 200 MHz .
• Impedance: 50 Ω, terminated to +0.5 V
Trigger - BNC connector (front)
• Level: -5.0 V to +5.0 V
• Resolution: 0.1 V
• Impedance: 1 KΩ or 50Ω
• Hold off: 500 ns minimum
AUXILIARY OUTPUT
SYNC Output - BNC connector (front)
• Level: Positive TTL pulse. 50 Ω
• Output Term: 6 Clocks
EVENT Output - BNC connector (front)
• Output Term: 8 Clocks
CLOCK Output - SMB connector (rear)
• Level: 1 V (Typical) into 50 Ω
IN EXCELLENT WORKING CONDITION
Asking Price $5,000 /If you have any questions, please feel free to contact me. Thank you....
• Output level
• Try-state control
Output Data:
Sequencer
AUXILIARY INPUT
• Resolution: 0.1 V
AUXILIARY OUTPUT
