Tektronix 2465B error code interpretation
JW
Hello all,
I have a Tektronix 2465B that powers up with the following error code:
CT TEST 84 FAIL 0C
Looking at the service manual I cannot find this particular code. I figure
that I'm mis-interpreting the code somehow. Can anyone shed a bit of light
for me?
Thanks.
robb
JW said:
Hello all,
CT TEST 84 FAIL 0C
for me?
Thanks.
I do not have one but i was researching the 2465 to buy recently
and i was looking for repair ease or cronic problems in various
scopes so this is what i remember....
CT is counter/timer option on that scope.
I remember reading somewhere there is an options service manual
, i am guessing that will probably cover the options like CT in
more detail i.e. errors/repair etc.
HTH
robb
PeterD
Hello all,
CT TEST 84 FAIL 0C
for me?
Thanks.
That the problem is in the CT and not hte scope?
Jim Yanik
Hello all,
CT TEST 84 FAIL 0C
figure that I'm mis-interpreting the code somehow. Can anyone shed a
bit of light for me?
Thanks.
CT is counter-timer,an option that has a separate service manual.
It probably will be hard to find one.
there also was a pricey extender kit for servicing the options.
(they plug into a options board on the top of the scope chassis)
You can probably make your own extender ribbon cables.
also,there will be a sticker on the back of the scope telling you what
options are installed,if any.
there also were scope handle stickers like "2465B CTS" or 2465BDM"
JW
Thanks very much Jim (and robb and PeterD). If I can't repair the
option, would you happen to know if it's possible to just remove it and
have the error go away?
robb
JW said:
2465BDM"
i think you can by pass the error with a combination button press
, i.e. hold three certain buttons and scope bypasses but i do
not know affect on the performance and operation ?
also there is a way to do a option calibrate or reset or clear
??? using some menu but my memory fails me
i am sure someone else can help with that,
hope you fix it
robb
Jim Yanik
Sorry,I can't recall,and no longer have access to the manuals.
It's not difficult to remove the CT card,so you could try it.
You may have to relocate some jumpers on the 2465 motherboard,the ones for
the signal pickoff for the CT option.
JW
Thanks Jim, I was unsuccessful in repairing it as I cannot find any
schematics, (It would be difficult even with them, as the problem was
intermittent, and access to the board without an extender would be
impossible) but was able to remove the option by disconnecting all the
cables from the CT card (option 06) to the A1 and A5 boards, and jumpering
the following points on the A1 board:
J101 1-3 and 6-8.
J102 3-4 and 7-8.
This has solved the problem with the error code, and has put the scope
back in service.
Many thanks once again!
JW
Yeah I know, but this failure for some reason was causing intermittent
sweep problems.
I couldn't find anything in the 2465B service manual about this. Oh
well...
hope you fix it
robb
Thanks for your help, robb.
Andreas Tekman
sweep problems.
well...
Thanks for your help, robb.- Zitierten Text ausblenden -
- Zitierten Text anzeigen -
Go to bama.sbc.edu (or the mirror site), there you can download a
manual with schematics, all error information, etc.
hth,
Andreas
Jim Yanik
hth,
Andreas
For the OPTIONS?
The options all came with separate service manuals.( a royal PITA)
And I believe they are kinda hard to come by these days.
When I think of all the TEK manuals tossed out when the Orlando Service
center closed...I coulda been RICH,if only I had had a place to store all
of them.
JW
On 17 Okt., 11:34, JW <[email protected]> wrote:
[snippo]
hth,
Andreas
For the OPTIONS?
Yep. I had no luck at all finding the schematic for the CT option. At ANY
price. Oh well, without the option the scope works fine, if a bit less
capable.
of them.
Tossed out?
*sob*
Jim Yanik
[snippo]
well...
hope you fix it
robb
hth,
Andreas
For the OPTIONS?
ANY price. Oh well, without the option the scope works fine, if a bit
less capable.
Service center closed...I coulda been RICH,if only I had had a place
to store all of them.
Tossed out?
*sob*
Yeah,and the same happened at all the other 7-8 TEK field offices that got
closed back in 1999. :-(
(there used to be THIRTY TEK field offices!!!)
PLUS,all the TEK semiconductor reference manuals [company confidential]
that got shredded/tossed! Now they put all that on the company intranet,and
only they can access it.
robb
JW said:
Hello all,
CT TEST 84 FAIL 0C
for me?
Thanks.
hey JW,
i hate having problems like that thus it stuck in my head
so... while searching for info on 2400 series (considering
purchase) ...
found your error
Check : CT
Test : 84
Routine: Gate Array (U6180) trigger path tests
Error : 0C
Boolean OR trigger failed to generate a sweep on
the rising edge of ATS.
Check U6180, Q5981, Q5982, Q5983, Q6090, Q6092,
Q6091, U5952, U6070
hope this helps
robb
Jim Yanik
hey JW,
purchase) ...
found your error
Check : CT
Test : 84
Error : 0C
Q6091, U5952, U6070
hope this helps
robb
if you could scan and upload your CT option manual to BAMA,it would be
greatly appreciated. Same for any of the other 2445/65 options.
