Sir bigone5500 . . . . . .aka Jared . . . . .
Firstly I wonder if you have tried adjusting the green blob control to its optimum ?.
Also, next, see if the bottom left intensity control causes it to get worse at its maximum CW position,
or getting better at its adjustment range towards the left. . . .CCW. ?
Now in retaining YOUR display but marrying on my controls on the right so that the panel can be read .
I am worrying about the compressed hoz display aspect. . . . .being basically due, just by controls / settings MISADJUSTMENTS.
In the central HOZ adjustments cluster, confirm that the unit is in its A time base mode and not in the B mode. by pressing A mode and the seeing if the RED circled hoz position will adjust the blob right to left positioning. If so. . .
Change the RED marked VAR time base control to the left to get a slower time base and an inherently increased brightness at the slower speed . . . . but shop well short of getting a slowly sweeping dot speed.
We are looking to getting a FULL line of sweep width.
Even with only your learners permit . . . . we are now authorizing the use of a small standard blade screwdriver to now adjust the recessed and slotted FOCUS control located within the bottom frontal left corner.
Any change ? if not, try astig and finally trace rotation, but NOT expecting anything from the last duo, due to the units present resolution capabilities.
If the FOCUS was dead of responding to any of those adjustments . . .ONWARD . . . to pull the dust covers and access to the central area of he units innards.
The area of interest will be marked by the easily noticeable and most honnable . . . MURATA RED AND BLACK cased high voltage multiplier and the SMPS transformer just across from it.
Our transistor of interest is marked up on both the schema and the picture.
We are interested in finding if the focus control adjustment produces any voltage swing at reg points RED A and RED B.
Standing by to see how you are making it . . . . . . . .
FRONTAL ADJUSTMENTS AND CONTROLS REFERENCING
SUSPECTED PROBLEM AREA SPECIFICAS
73s de Edd
