TekMan
Hi folks,
this time I am looking for your your help:
I have a tektronix 2246 model A (the mil. version of the 2246).
Everything is working fine, except brightness control: Both (A and b
intensity) are stuck a highest brightness.
I already checked the intensity pots (going smoothly -2.5 to
+2.5Volts),
all voltages from the LV power supply (-7+ 7.5 -/+ 15V, 130 Vdc,
130Vac ): all fine, low riple.
High voltage seems ok, since I can focus the beam very well and
readout is clearly visible.
So, has anybody some voltages of the HV supply in mind or on schematic
-- then I can compare it with my readings.
A partly scanned schematic of the HV/crt part would be welcomed too.
and_de AT gmx.de for scans.
Has anyone an idea where to continue with fault search? Jim, any known
problems in this area to you?
Thanks for any help and ideas in advance!
Andreas
+2.5Volts),
Andreas
