I just recently bought a Tektronix 2215 scope. I checked the scope out and everything is calibrated and is very accurate. The problem is when displaying a sine wave below 1 Mhz the display is fine, has good brightness. Putting the scope in XY mode with just a spot on screen it also has good brightness. When you start going over 1 Mhz the trace gets dimmer the higher in frequency it goes. By the time the frequency reaches 25 Mhz you can barely see the trace. Its still accurate just really dim. The intensity control gets really touchy and turning to far to the right or to far to the left and the trace will disappear. Ive checked all the power supply voltages and they are all within specs. I don't have a HV probe so I haven't checked the high voltage. Anyone have any ideas?
Platforms
Content
