Jim said:
Jim Yanik
jyanik
at
kua.net
Hi JIm - seeing your name reminded me of a discussion about a Tek 475
we had yonks ago - it had a blown eht generator transistor. It was
suggested that the closest equiv. to the TEK original was a 2n3055., I
think SPHERE list this. Experimented a bit - found a common TV
horizontal output transistor worked - cant remember what it was, but
its a BUX something - 70's vintage Philips - TO3 case- out of a junked
chassis sitting under the bencg.... Worked this out by using external
current limited power supply to feed cct, and looked at waveform on
base of transistor, as per diagram in manual - the TV one gave the
proper waveform, the 3055 had big spikes (why, I dont know - I am not a
engineer) The other problem was that huge film type resistor
(300MegOhm?) in the EHT feed back cct had gone LOW in value - this one
stumped me for a while, never seen a resistor go low, usually high.
physics is (apparently) copper migration from terminals, only happens
in HV circuits.
Anyway, now goes OK - last fault is, after an hour or two, the trace
intensity starts varying......one day, when everything else is done,
will tackle it....
Is it a nice scope - YES!!!!!
Would I do up another one NO!!!!!!!! (Chewed up heaps of time and
money ) - a previous fault (it was given to me as a junker) had me
replacing the EHT transformer, the EHT multiplier, the CRT, and the IC
that drives the vert plates........too open ended.......
Andrew VK3BFA.
