Phil Allison said:
"Kevin Hope"
** I strongly advice you to KEEP your analogue scope !!
For audio work and other general analogue work, they are far superior.
Analogue scopes are intuitive to operate, present all waveforms in REAL
time, the bandwidth is fixed instead of changing with the time base
setting, there is no aliasing to drive you nuts and most of all, the CRT
trace gives far more detail, resolution and information about a waveform
than an LCD screen.
Obviously, a good digital scope can do things an analogue cannot (and vice
versa) - so owning one of each is best particularly if you need waveform
capture, signal averaging or on screen measurements of time and voltage
etc.
Look I have to agree with Phil, DSO's do feel quite different to an Analog
scope I have both and tend to use the DSO more as a portable (it is a TDS210
and is lightweight and easy to carry), where I need to capture waveforms,
where I want to look at what happens before a trigger and other odds and
ends like that and use an Analogue for most other work.
Bear in mind that a DSO can give you aliasing problems as the Sample rate
does vary with the sweep speed - In fact the Users manual for the TDS 1002
specifcally has a section on this issue (Download the Manual for the TDS1000
and 2000 from the Tektronix website pages 20 to 23 deal specifically with
aliasing).
I have to admit that even though I am familiar with aliasing it has still
caught me out on occasion even though I have by and large developed the
habit of double checking signals at different sweep speeds to get around
aliasing
Of course DSO's do have their uses and the capture facility is great for
looking at non repetitive events such as pulses and digital signals
(although I also tend to use a logic analyser when I am getting into more
detail with Digital issues) and if you can get used to there quirks they can
do a fine job. But you do need to remember that a DSO is a different Beast
to an Analogue scope and does handle things differently. in fact the DSOs
real strength is in its storage capability and the Persistance mode can be
quite usefeul for comparing repetitive waveforms.
If you are used to an Analog scope then For goodness sake do not go out and
swap your analog scope for a Digital one - it will probably drive you
insane.
If you have uses for a DSO and are used to an Analog one then I suggest you
do what I do and have both - You can make your mind up later which one you
prefer if you only want to keep one but do not commit to a DSO until you are
used to one and by this I mean have used one for a while not just bought one
home and plugged it in.
Might I also suggest if you wish to go Digital that you try some of the DRT
(Digital Real Time ) Scopes as they do have more of an Analog feel than the
normal DSOs - although they do still have aliasing issues etc and I strongly
recommend that you get used to one before you replace your analog scope.
Regards
Richard Freeman
