Tech Help Needed: Sankyo Stereo 800 projector
jandree
Hi All,
I recently picked up a Sankyo Stereo 800 projector. After getting it
home I realized it was not working. When you plug it in the projection
bulb comes on dimly but the motor will not run. The sound side of this
projector seems to be functioning properly, but the motor doesn't turn
when the control is put in any position. I pulled the cover and all
belts are intact, and the motor turns freely when spun by hand. There
is 9.5 volts present at each motor lead when checked to the case as
ground. Any ideas or suggestions? Anyone no the proper motor voltage?
Have a spare schematic?
John
