Tec 2445 Start up 'bright spot' ?? beam set , hot or cold ?
G
Graham
Have I a problem or is this normal ??
On power up , there is a short period of nothing , followed by the
front panel -center lights short flash- then trigger lamps ligth and
reamin lit , scope then runs normally ... I think this is normal
start up -checks-
But I get a very bright spot on the tube before , normal operation
starts , normally center bottom screen- only for a short time may be
1/5 second ...
ive the set the eht board up -twice- now , for intensity, as in no
spot at zero control setting ..I find that when the scope is 'cold'
with zero intensity setting , i get a slight trace , as it warms up ,
15 mins or so , this falls to 'zero' as i had set up ..
Q is the bright spot at start 'normal' , and should i set the beam
cureant with the scopr hot or cold ... i would of thought 'hot' ?
Tnx
Grahm ..
Jim Yanik
start up -checks-
1/5 second ...
Too short to do any harm.
Tnx
Grahm ..
make adjustments to the scope after a 20 minute warmup.
G
Graham
Jim Yanik
jyanik
at
kua.net
Ok thanks for that Jim,
Ive finally sorted the scope out , .after sorting it the first
time , found the y2 bnc socket middle had become loose .. replaced
that .. . I ran over the eht board set up , (all 6 pots) after it had
been running about 4 hours ..
Q you mean set after 20 mins .. or a minimum of 20 ? ie was 4 hours
too long , I assumed it would be best at working temp ? ..
On the start up 'spot' I must admitt , I cannot remember if this
happend in the past or just since i have changed the eht boad , Is
there a set up for this or is a 'normal' function .. stays for about
the time to say 'one' then the main trace and data displays slowly
fade up .
At least it working
Tnx
Graham ..
