Jason D.
Came in sick unresponsive, have standby power and CR4118 correct.
After cleaning up area removed parts to get at ick and cleaned removed
individually. Now ick is all gone on everything. That pair of caps
that oozed on the jungle area also replaced. Jungle IC replaced from
another chassis. Got it going but turn off and back on blew HOT.
Darn! Replaced horizontal driver filter cap (4.7uF 50V), worn out
22ohm resistor (part finder specifies 1/2W (done, old resistor was
factory 1/4W , new HOT from RCA got it going great and many turn off
and on didn't blow HOT, runs cool.
Current problem: Tearing or spinning horizontally lines at a
diagonals.
Now last problem is seen finally. Fast horizontal tearing like you
have wrong horizontal freq locked in on a old monitor with off freq
horizontal feed. Did get good audio, B+ is right on.
CR4118 voltage in run mode is even better than I've seen, 13.8V
Any comments? Googled with no luck, tried www.8ati.com website forum
for info, not have this problem.
Cheers,
Wizard
diagonals.
Cheers,
Wizard
