I have an inexpensive Chinese TDA7297 module that I want to use to replace the audio output stage of an old car radio.
The problem is that the module does not have enough gain. The radio is mono and the module is stereo so I was wondering if I could cascade the channels to get more gain. Basically I want to connect the output of one channel into the input of the other channel.
Because the inputs are relative to ground to cascade the channels means that one output leg of the ist channel gets grounded via it's connection to the input of the 2nd channel. I'm not sure if this upsets the working of the module. I suppose I could insert a coupling a capacitor in the grounded leg but I'm not sure if that is all that's necessary..
BTW, because the car speakers have one wire grounded the output channel of the module also needs one speaker output leg grounded. So basically both channels would have one output leg grounded. I'm not sure if this complicates things or not.
I don't have a schematic of the module, I only have the TDA7297 data sheet and I have posted the link below.
Anybody have any suggestions?
http://www.radiotechnika.hu/images/TDA7297.pdf
