Tandberg 3001 tuner - broken gear
Tim Schwartz
Hello all,
I've got a Tandberg 3001 here where the small plastic gear that drives
the tuning pot (opposite end of the shaft from the tuning drum that the
dial cord wraps around) has cracked. If Tandberg were still around, I'd
just order the assembly. In this case I either have to have the part
machined or find a 'basket case' to pull the part from.
The service manual that I have does not include the parts list, so I
can't tell you the Tandberg part number. I'd guess that the 3011 tuner
uses the same part.
Anyone have a parts unit?
Regards,
Tim Schwartz
Bristol Electronics
Sofa Slug
: Hello all,
: I've got a Tandberg 3001 here where the small plastic gear that drives
: the tuning pot (opposite end of the shaft from the tuning drum that the
: dial cord wraps around) has cracked. If Tandberg were still around, I'd
: just order the assembly. In this case I either have to have the part
: machined or find a 'basket case' to pull the part from.
: The service manual that I have does not include the parts list, so I
: can't tell you the Tandberg part number. I'd guess that the 3011 tuner
: uses the same part.
: Anyone have a parts unit?
: Regards,
: Tim Schwartz
: Bristol Electronics
Look Here:-
http://www.sdp-si.com/web/html/products.htm
I got some gears from them to repair my HP 8640B Sig Gen.
Colin @ CATronics
And...
http://tinyurl.com/Gears-Small-Parts
