Hello,
I need to come up with a method to brake and stop a wind turbine from turning when a certain wind speed is reached. For the wind turbine generator, I'm using this motor http://uk.rs-online.com/web/p/dc-motors/2985076/ .
I was considering using regenerative braking but that would not lock the wind turbine. I'm stuck at this point
The wind turbine is small, about 0.4m x 0.4m x 0.4m
Background information: I'm designing a braking system for a mini wind turbine. My idea is to connect a low value resistor across the end terminals of the motor to increase current and torque. When not braking, there is a 10 ohm resistor connected across end terminals of the motor by default. I only need a basic idea for a circuit since this project is in early stages.
http://i.imgur.com/h7HnxCP.png
Is this something I should be aiming for or is that stupid?
Also this braking system should be activated once the wind speed reaches a certain speed, If I have a device that measures wind speed how would I create a circuit so that I get the 0.1 ohm resistor between the end terminals of motor instead of 10 ohm resistor automatically
All help is appreciated.
With thanks
Maru
With thanks
Maru
