Synchro Amplifier Help
Matt
Hello,
Unfortunately, I was raised in the digital age and dont have a
great grasp of Synchros. I am trying to develop a replacement to a
synchro amplifier that we use for a piece of military equipment. From
me research I have learned quite a bit about the Synch amps but I still
have some questions.
The input is a resolver 6V 60Hz (and another amp at 400Hz). This
voltage then needs to be matched to the input of a Scott T
transformer(I think). This is then turned from sin(x) and cos(x) to S1
S2 and S3. Does S1 S2 and S3 come out at 90V out of the Scott T? I
think I have it correct up to there except the voltages on S1-S3. Now I
would personally send these three AC waves to a power amplifier (or a
voltage amplifier first if S1-S3 are lower then 90V AC). Then after
these power amplifiers and some circuit to detect a rotor lock, can I
connect it to an output, or am I missing something. Other designs I
have looked at (CCC,CSI...etc.) Seem to have a pulsed (pwm?) power
supply that uses the boats power as a reference. What is this thing
for? Is it necessary?
Sorry for all the questions, and thank you for the help,
Matt
Tim Wescott
Matt said:
Hello,
It's not clear what the 400Hz amp is doing -- are you somehow getting a
synchro output with a 400Hz reference? That sounds oddball, but it may
even be an off-the-shelf item for all I know.
That depends on the Scott T. Assuming that 90V is a common standard,
there's a good chance that it does -- but the only way to be sure is by
careful study of the system or by measurement. Even if the Scott T is
designed to output 90V it still must get the it's design input from the
resolver, so you're not off the hook from measuring it or doing more
analysis.
I
That sounds good AFAIK. I'm not sure that rotor lock is even essential,
except as an executive feedback / startup / BIT sort of thing.
Other designs I
A switched amplifier is much more efficient than an analog amplifier.
With todays semiconductors you can usually build a big amplifier cheaper
by making it switched -- the semiconductors are smaller, the heatsinks
are smaller, you don't require so much power from the rail, etc., etc.,
etc. About the only downsides are an increased potential for radiated
EMI and a much more complex design task.
Tim Wescott
Wescott Design Services
http://www.wescottdesign.com
Posting from Google? See http://cfaj.freeshell.org/google/
Matt
Tim,
Thank you for the help. I will go ahead and design an analog amp at
first then move towards a switched on (is it simular to a switched
power supply? 20kHz+ oscillator into a transformer?)
Matt
Tim Wescott
Matt said:
Tim,
Matt
Ahh - you're posting from Google and you didn't read the link. Tsk tsk.
In a way a switching power supply _is_ a switching amp, or at least it's
a power supply _with_ a switching amp. The big difference is that a
switching amplifier almost always needs to provide four (or at least
two) quadrant operation, which means you have to use a half-bridge drive
instead of a pass transistor and steering diode.
Of course half-bridge drive means the possibility of shoot through, and
shoot-through means little bits of FET package scattered around the lab.
All in all it's a process that's more fun to watch than to make work.
Web search on "switching amplifier" and "Class D amplifier" for more info.
National and TI both have nifty parts for audio, but they only work
within their rails and they don't have military temperature ranges.
Apex semiconductor has nice switching amps, as long as you have a pile
of money and a shovel.
Tim Wescott
