Symbol LS 2080 Scanners, Decodes and Beeps Twice Help?
G
Guest
Hi
I have been doing scanner repairs for about 6 Months I have a particular
error that I cannot fix. I have not technical manuals all the logic I have
had to figure out.
1) The scanner appears to go through the programming with no problem
correct beeps and sounds.
2) I have replaced 74hc14 on the input.
3) I am presuming it is some sort of programming error.
Is there a utility of some sort of if anyone can help with a solution
please.
techforce
Sounds like a Low Battery.....or could be it needs to be flashed with new
Data to catagorize that particular Bar Code.
Does it do it with Any style of Bar Code, or just Certain ones?
| Hi
have
| had to figure out.
| please.
