Swithching regulator (Buck Converter) with LTSpice question
Hello, I'm in the process of learning switching regulator and I'm using LTSpice as a simulator and teaching help. I found a video on YouTube explaining the SR, and I did exactly what it was demoed and didn't get the same results.
Simply said, I getting the same result but with a 300mV at the output instead of 5.6V, why ?
Here is the link of the video :
In attachment, you will find my LTSpice schema and a few screenshots.
Thanks a lot!
  • SBEC-T01.asc
That is rather logical as you've set D=0.05 whereas in the video it is D=0.5.
1/10 duty cycle -> 1/10 output voltage (roughly).
Cheers,
Harald
