Joel Kolstad
I have a VCO that using varactor tuning internally along with a "hang inductor
on this pin" approach to set the center frequency. In my case, that center
frequency is around 400MHz and the inductor turns out to be ~22nH (working
backwards from the data sheet, internally the varactors are between 5.17pF and
7.44pF as you change the tuning voltage).
I'd like to extend the tuning range of the VCO, and figured that, as the
varactors have a range of ~2.27pF, if I could switch in a ~2pF or so capacitor
in parallel with the inductor, the tuning range would be extended. I soldered
down a 2pF cap and verified that the VCO range does drop as predicted, so the
only problem is: How do you switch in something so small as a 2pF cap? Most
devices I'm aware of -- MOSFETs, a discrete varactor diode, etc. -- tend to
have 10x as much parasitic capacitance and therefore appear as a short to the
2pF cap without providing any significant switching action.
Another problem is that the oscillator's output is ~1.5Vpp (centered at ground
due to the inductor), so I expect that things like a PIN diode would just
self-bias and also turn into a pretty good short.
Any ideas?
Thanks,
---Joel Kolstad
Any ideas?
Thanks,
---Joel Kolstad
