Okay folks, I have a rather mysterious problem here with an arcade power supply. Basically, this is a switching power supply that runs from 100VAC, and supplies 3.3, 5, and 12VDC.
The voltages are all fine, however I'm having the weirdest problem ever. Whenever I use this power supply with an arcade PCB, I'm having graphics issues that develop over time, or the game connected won't even boot up.
When a game won't boot up with this power supply, if I leave the power supply running, and just disconnect and reconnect the power connector on the game board, the game springs to life, but as with almost all boards, will develop graphics glitches over time. The game boards all work fine on other machines.
I'm thinking the PSU probably has capacitor issues?
Does anyone know what I should be looking for on the outputs with an Oscope? Or a guide on how to check power supplies for unfilteredness?
I could just swap all the lytics in it and see if that helps, but I'd like to actually pinpoint the issue.
Thanks guys
Thanks guys
