Switching Power Supply
Hi guys I want to ask you,
How to parallel switching power supply in correct way? I need the schematic diagram for it, thanks
hevans1944
Hop - AC8NS
What makes you think this is possible? Who is the manufacturer of the switching power supply, what is the model number, how much output voltage at what current level will a single power supply produce? How many do you need to operate in parallel? Is there a provision for synchronous switching of all the power supplies, or do you expect them to run independently? You need a schematic diagram? Have you contacted the power supply manufacturer and asked for one?
Hi hevans thanks for your response, I have 5 x 30a 12 volt power supply, and I want to get 150a output, before that i am doing experiment (but with low ampere 3x3a 12volt and it is succeed i get 9a exactly) i put ceramic resistor with mili ohm and high wattage value, also install diode in series to terminal output, i get those reference/solution in other forum, but I am not sure if paralleling in big ampere will succeed also, i need correct value of each Component,btw it will be difficult if i contacted the manufacturer in direct, but I will try to reach them, this i send you the model of power supply IMG_20200930_203206.jpg
The main advantage of the switching power supply is greater efficiency, up to 96 percent, than linear regulators because the switching transistor dissipates little power when acting as a switch.
davenn
Hi hevans thanks for your response, I have 5 x 30a 12 volt power supply, and I want to get 150a output, before that i am doing experiment (but with low ampere 3x3a 12volt and it is succeed i get 9a exactly) i put ceramic resistor with mili ohm and high wattage value, also install diode in series to terminal output, i get those reference/solution in other forum, but I am not sure if paralleling in big ampere will succeed also, i need correct value of each Component, btw it will be difficult if i contacted the manufacturer in direct, but I will try to reach them, this i send you the model of power supply View attachment 49444
Dunno if you did that labelling or not ??
but there are lots of mis/bad labelling, here's an edited version
Now in reference to your text .... You are NOT going to get 150A out of that PSU
You would have to change virtually EVERY component in the PSU
