Hello, my electronics experience is quite limited.
I am using a raspberry pi to control a servo - But I am switching it on/of via a transistor, not using pwm. Reason being, pwm is limited to the servo's 90 degrees rotation. I power the servo motor directly to get 360 degrees rotation.
Problem: To turn the servo the other direction, I need to reverse the polarity.
Currently I have the following circuit (the lamp is my servo):
This works fine, but I can only rotate the servo one way when switching gpio to high.
I am thinking of a way to do the following somehow:
- duplicate the transistor circuit using another gpio
- use the same voltage source for the second transistor circuit in reverse - somehow blocking flow with diodes maybe to prevent the short circuit? Only one of the gpio/transistor bases will be on at any point in time.
I would appreciate any advice.
