Hi !
I'm just wondering , what would happen if I switch a 12VDC lamp using the alarm relay output of this temp controller? with the following parameters below in the uploaded file . Here it says that it has a 1A 250VAC capacity , it does not indicate its DC capacity or is it only for AC loads ?
and also, if switching DC loads to a relay with AC drive capacity indicated is possible, what would be the hazards or possible consequences of doing this besides failure if I exceeded the relay's drive capacity ..?
the operation would be if the temp controller reaches the assigned limit value, it will trigger the 12VDC lamp ON using its relay output .
