Hi friends.
I come to you because I have a problem that I cannot solve.
I have 2 chauvet moving heads that have the same defect in the power source.
At first they work but after a few seconds the 2 source voltages drop and try to go up again but fall again.
I unplug it, wait a few seconds and turn it back on until it falls off again. I unplug it again and it doesn't even have time for the head to start.
The problem is in the power source.
I have already measured everything and I don't know where the fault could be.
I see with the oscilloscope how all the pulses work but only half a second and all the voltages rise to a point and start to fall and rise again with a frequency of about 1 second.
I am very struck by the fact that the power supply voltage of the chip that controls the pulses also falls and rises again, I cannot understand if that is the primary failure or not or where the voltage to power it comes from.
I don't know much about switched mode power supplies but I have all the instruments and the knowledge of electronics to make all the measurements that the experts advise me.
Greetings
Greetings
