OK so this eels like a dumb questionn but I took a SPST with an indicator light that is set up so that when the switch is on, it also completes the circuit on the indicator LED. The - wire on the indicator LED is connected to one prong and there is a 3rd prong for the indicator LED's + wire. The indicator LED runs on a separate little battery. I wanna is use this on an ebike but to do that, I must connect a "power on" wire to the system + wire. If you put your multimeter probes on the "power on" wire and the system + wire, you would read system voltage. Can I use that same set of prongs to carry the - wire that powers the indicator LED? So, would I not burn out the LED by somehow giving it the full system voltage (48V)?
Pic not related![upload_2021-7-2_23-50-24.png upload_2021-7-2_23-50-24.png](https://makerv2.webteractive.co/forums/data/attachments/50/50691-d651d368a4f57b7ec36b881a4dbb89ab.jpg)
Pic not related
