I don't understand the question, but a filter is a circuit that only allows a certain frequency or a range of frequencies to emerge from the circuit.
A LOW PASS filter only allows the LOW FREQUENCIES to emerge.
The simplest filter consists of a capacitor and a resistor.
We know that if we place a capacitor with one lead on the 0v rail and connect a voltage to the top lead, the capacitor will take time to charge and discharge.
The capacitor is just like a battery and we are trying charge it and discharge it. This takes TIME.
It is a slow process.
So, if we connect a signal to the top of the capacitor, the low frequency signals will charge and discharge the capacitor and we will see the result by the voltage rising and falling.
But if we connect a higher frequency to the top of the capacitor, the signal will rise too fast and fall too fast and the capacitor will not be able to follow.
It's like expecting your flat car battery to get fully charged in 10 seconds. It is not going to happen.
We can now add a resistor as shown in the diagram and this resistor does not change the concept of what we are saying. It is just designed to prevent damage to the incoming signal.
The capacitor in the diagram will allow low frequency signals to charge and discharge the capacitor and thus the signals will emerge from the filter.But the high frequency signals will simply be lost in the process of trying to charge and discharge the capacitor AT THE WRONG TIMES.
I can't make it much simpler.
