panfilero
i have a problem, i need to switch an LED on from an open drain output. Theopen drain output can have no pull up tied to it, it can only be Low and HiZ. I was thinking an n-channel jfet might do it, but then i thought... nope, I can't clear the jfet once it turns on unless I can pull the gate high(I can turn it on by pulling it low, but showing the gate HiZ will do nothing)... is there anything that switches based on a HiZ or Low signal?
much thanks
much thanks
