Sweet sweet vacuum tubes...
Hello!
This is my first post on Electronics Point. I am fairly new to the electronics world but I am learning my way around. Next fall I will be beginning school for Electrical Engineering, and in the mean time I have been trying to soak up every bit of information I can. But to cut to the chase...
I was playing around earlier, looking at schematic of various tube amps and preamps. I decided to try my hand at drawing up a feasible schematic of a medium mu preamp, and this is what came out.
Does this look like something that would work? Just curious if my knowledge is leading me in the right direction. Any input on this design would be greatly appreciated!
I see no way to get current into the valve.
This is not a voltage amplifier, it provides a low output impedance which you have killed with a 100k resistance.
The rectifier is all wrong, you need two diodes pointing to the positive line and two diodes pointing away from the negative line. That is all diodes should be pointing up with the AC connected each side halfway up.
Well, thank you. I will now quietly crawl back into my hole until school gives me a better clue of what I am talking about.
Spring is on the way in the northern hemisphere, now is the time to crawl out of our holes.
Redraw the power supply as I suggest and when that is right, we will go from there.
Warning:
Americans call them 'vacuum tubes'.
Brits and Aussies call 'em 'valves'.
Just in case you were confused about that last post.
