F
Fred
I have small CTV with Single Horizontal Line, so I suspect the vertical IC
as it drives the yoke directly. I also know that something is drawing to
much power as the light bulb trick lights the bulb quite well and the power
supply does not start in standby. In generic terms, can I start the set with
the IC removed to see if its gone bad inside ?. The IC is $35 no return
