Hi.
I am having a bit of trouble with a device I manufacture. When plugged directly into the mains it operates perfectly fine with no issues at all. This has been the case for for the past 18 months.
Recently i have had a couple of returns where the device acts strange.
I dont want to give away all the details due to it being a commercial product and anyone can read this.
The device has a built in isolated PSU that powers 2 microcontrollers and an LCD display with touchscreen. One of the microcontrollers control a Triac via an opto triac.
So on a straight up mains supply it operates as expected no issues for the past 18 months. However when plugged into a surge protector it takes minutes to start up. When it does eventually start up then it restarts every few minutes.
If using the very cheap surge protectors the LCD displays controller is damaged and will not respond to any commands from the microcontroller.
I have spoken to Masterplug about this and they have no idea why its happening. I find it odd that they work flawlessly until plugged into a surge protector.
One such unit was returned as the LCD display was not responding. after establishing the surge protector being plugged in i replaced the LCD and returned the device. That same device has run flawlessly now for over 12 months.
Is anyone able to shed any light on possible causes as myself and Masterplug are both stumped as to the problem.
Thanks in advance.
Thanks in advance.
