E
|-|erc
Any ideas how to record faint background noises? All the mikes I tested you have to speak into.
Herc
Herc
|-|erc said:Any ideas how to record faint background noises? All the mikes I tested
Herc
Herc
JERD said:We sure need more information on this question!
David L. Jones said:Most regular omnidirectional electret mic elements are very sensitive.
http://jaycar.com.au/productView.asp?ID=AM4010
Used in their zillions in standard PC desk mics and headsets etc.
Gain'em up as required.
|-|erc said:I had a FM bug that was more sensitive than the human ear, when
someone was pouring a cup of tea I could hear it swirling and the pitch
increasing. But
the FM bug I just got from Talking Electronics was not very sensitive.
David L. Jones said:All of the Talking Electronics bugs I built as a kid all had a standard
electret microphone and could pickup anything "better than the ear" as
you've found before.
The new one you have obviously doesn't have enough gain, and/or has an
insensitive mic. Perhaps it's designed for a different application?
Can you change the gain on the front end amp?
I'm sure Colin Mitchell at TE will be able to tell you what you need to
know.
Maybe there's a maser beam converter program somewhere that will convert theTrevor Wilson said:**Depends on what you are attempting to do. Usually, a good directional
mic will provide what you want. There are a couple of variants on
directional mics. You can construct something yourself, using a mixing
bowl, with the microphone mounted at the centre. Similar to a satellite
dish.
Rheilly Phoull said:Maybe there's a maser beam converter program somewhere that will convert
the beam into audio.
|-|erc said:I had a FM bug that was more sensitive than the human ear, when someone
was pouring
a cup of tea I could hear it swirling and the pitch increasing. But the
FM bug I just got
OK maybe its my radios. I tested it on a radio with a broken antenna and
a
MP3 player with a digital tuner, which went up in increments of 0.05 MHZ
so it might have been out a bit. I'll get another radio to make sure it's
not the
bugs fault.
Peter Parker said:A tuning step of 0.05 MHz is fine for bugs (unless the bug's deviation is
really really low).
The broken antenna will restrict the range but not the recovered audio.
beam into audio.
Trevor Wilson said:**Huh?
Rheilly Phoull said:Did you read the post ??
Mark said:Lets assume for a moment there is a satellite that can punch a maser
beam powerful enough to heat surface air enough to modulate audio.
You'd spot it's presence by the burnt spot on the ground caused by the
microwave heating and by people exploding as their fluids turn to
steam.
Still it would be awesome to throw your voice at right/wrong place,
picture two teams of diplomats sitting tensely at the negotiating
table as one party awaits the reply of the other and a voice suddenly
says the wrong thing out of nowhere.
Mark Harriss said:Lets assume for a moment there is a satellite that can punch a maser
microwave heating and by people exploding as their fluids turn to steam.
In actual fact I suspect you are hearing a certain Sydney toaster/
microwave oven repairman due to cold weather atmospheric ducting of
microwaves under repair.
And the entire battle fleet was accidentally swallowed by a small dog.Mark said:Still it would be awesome to throw your voice at right/wrong place,
says the wrong thing out of nowhere. http://www.cgoakley.demon.co.uk/vlhurgs/
