[Severe cuts applied to get to the essence here.]
Active8 said:
I didn't get that from the app note. It's the cutoff freq for a
single pole lowpass filter. I dug up the appnote for the OP.
Ok, I assumed you got it from the app note you quoted
because it seemed too long a coincidence that the same
misconception would appear independently.
It's also the freq where the reactance equals the resistance, which
is the cutoff freq of a one pole RC filter. Notice the equation you
gave is similar to the eq for a simple passive RC integrator/LPF ?
Similar, perhaps, in the appearance of a similar
term, (2 pi R C), but not similar enough to turn a
low-pass filter configuration into an integrator.
Yeah, they called it an integrator in the Army - when that was it's
intended purpose. Good enough for gov't work?
You don't need to
point out that the charging current will not be constant as the cap
charges up.
That is is an important aspect of the difference between
a low pass filter and an integrator. In the passband of
an RC LPF, the cap does more or less charge up so
that there is little loss across the R and, more importantly,
the output magnitude asymptotically approaches the
input magnitude. That never happens in an integrator
except, in an op-amp realization, at the absurdly low
frequency where the amplifier operates nearly open
loop.
They used RC passive "differentiators" too. Square in,
sharp pulses out.
Calling an RC high-pass filter a differentiator is much like
calling an RC low-pass filter an integrator. So I have to
hand it to you for consistency. said:
---/\/\/\/---+--- Vo/Vi = 1/(1 + RCs)
Strictly speaking, (and going along with considering
only the magnitude), it is 1/sqrt(2) at Fc for that circuit.
But there is no passband! The pole is at 0.
There is simply no pole at 1/(2.pi.R.C) as you
have claimed, which is what got me into this.
[big snip]
There was nothing to be gained by quoting text irrelevant to my
reply. As I said, I checked the mfg and AN # for the OP. First you
ream me for not cutting enough chaff from my code, now you're
complaining about me snipping posts
Well, if I was complaining it was only about this
short and almost simple statement that vanished:
[T]he integrator gain is -1/(s*(R*C)) for each input R.
That really says it all. There is no cutoff frequency
because there is no passband with a single pole at 0.
And I'm sorry if you felt reamed. I often try to
persuade programmers that they can often solve
their own problems by trying to reduce their code
to a minimal problematic version.
Likewise,
