Bill Proms
I have a small platform that has a pocket videocamera attached to it.
Since I have the camera and platform in a remote location, I need to be
able to move the camera slightly in two dirctions: toward and away from
an external lens (the lens is not attached and focus is done by moving
the camera toward or away from the lens) and also slightly in
perpendicular directions to and fro (because some objects are not
centered in the lens and the camera can move slightly to compensate).
I first tried making two small stacked platforms on top of modified
drawer sliders with strings attached. The idea was to pull a string to
move the camera in either of the directions above, but there is too much
stress needed to get the camera to move and I must find a better way.
Then the idea has occurred to attach a nut to the bottom of each
platform and then use a threaded rod with a motor attached to the rod to
move the platform in either direction. Since the camera needs to be
able to move slowly in any of the directions and go forward and reverse,
I'm not sure what type of motor would be suitable. I have some 3 Volt
DC hobby motors, but I think these are way too fast for the job plus I
doubt they reverse direction with polarity change. Can someone suggest
a suitable motor, preferably something surplus? BTW, the threaded rod
wouldn't need to be anything larger than 1/4" diameter or so.
Thanks,
Bill
Thanks,
Bill
