such thing as quadruple pole double throw switch?
Dirk Funk
I pulled a switch out of a guitar effect pedal from the 60's that has
this lay out.
A B C D
1 2 3 4
A to B is a circut and C to D is a circut, when you throw the switch
the circuts are 1 to 2 and 3 to 4. What kind of switch would this be
called?
Anthony Fremont
this lay out.
A B C D
1 2 3 4
called?
If there are no other pins on the switch, it is an odd one. However,
you can take an ordinary 4P2T switch (yes they do exist ;-) and connect
the commons as two sets of two. IOW, connect common-1 with common-2 and
connect common-3 with common-4. You can then connect your wires to the
outside terminals just like the original switch. Hope this helps.
