Substituting capacitors with different voltage ratings?
Tristar
I'm starting out building a simple 555 tester circuit before I move on to
the more complicated bike timer. I was wondering what the possible effect
on using a 1uF cap with 50 volt rating instead of the suggested 1uF 16
Volt?
Lawrence
John Fields
Volt?
Dr Engelbert Buxbaum
Volt?
Electrically you can substitute with a higher spec. However, if you are
using a printed circuit board the 50 V type may not fit mechanically,
since it will be larger than a 16 V.
Michael A. Terrell
You also have to be careful about substutions in circuits requiring
low ESR cpacitors.
Link to my "Computers for disabled Veterans" project website deleted
after threats were telephoned to my church.
Michael A. Terrell
Central Florida
Jasen Betts
Volt?
It'd cost more, be bigger, and possibly last a little longer. :)
With capacitors the voltage rating is the maximum volts it can handle.
so a 50V capacitor is more rugged but otherwise electrically identical to
a 16V part.
Bye.
Jasen
