Platforms
Content
Yep, they have the same part number and are probably very similar parts.
It's always with checking out the datasheet just in case the one you're substituting doesn't have (say) a higher maximum supply voltage that may be important in the circuit you're making
Thanks mahn for the help.Exact same part. The CD part was first introduced by RCA when they developed CMOS for the market. When Motorola got into CMOS, they started all of their parts with MC - Motorola CMOS.
Note that that is an old, early part, and is "unbuffered". Early CMOS parts were *extremely* sensitive to static electricity damage. 2nd gen parts usually have a B after the part number, indicating a buffered chip with input ESD protection and a buffered output stage that can handle more current and brief short circuits. The 4049 was kept unbuffered because many designs depended on that "feature", and did not work with the newer parts. Some people mark the 4049 as 4049U or 4049UB for this reason. Same with the 4069. Consider the 40106 as a more robust alternative.
ak
Actually i didnt get u..i am a kind of starter in circuits..can u help meYou say you are making a DC to DC converter. Are you aware that CMOS circuits have very limited current source/sink capability, so will need an output buffer stage to drive any significant load?
Its a 12 to 40 v converter..this is for my project purposeWhat output voltage and current do you want from the converter?
Are you building the converter as a learning exercise or simply because you need one (it may be cheaper/quicker to buy a ready-made one)?
