I'm working on a display monitor which is used in a wheel alignment
machine in a garage. The unit is a type of VGA monitor which was
manufactured by Kristel Corp. It has problems and I would like to see
if I can substitute a standard VGA monitor in its place. It uses a
special connector which according to the schematic has the following
connections:
1- Red in
2- Red ground
3- Green in
4- Green ground
5- Blue in
6- Blue ground
7- Common ground, (common with video grounds)
8- H-sync in
9- V-sync in
10- NC
There is a 75 ohm resistor from each color input to ground. All
grounds are common.
I found a pinout for a 15 pin VGA connector. It is marked:
Standard VGA
monitor pinout
1 Red Video
2 Green Video
3 Blue Video
4 Monitor ID - Bit 2
5 Ground
6 Red Ground
7 Green Ground
8 Blue Ground
9 [KEY]
10 Sync Ground
11 Monitor ID - Bit 1
12 Monitor ID - Bit 0
13 Horizontal Sync
14 Vertical Sync
15 N/C (Reserved)
I would like to try to use a standard VCA monitor for this
application. Can I use the substitute monitor by connecting its RGB
inputs to the alignment machine electronics RGB connections, then tie
all the grounds together, and then connect the h and V sync to their
appropriate pins? Do I need to worry about the other connections? The
OEM monitor doesn't seem to use any of them The following is what I
have in mind:
Standard VGA Oem cable from
from alignment machine
monitor pinout
1 Red Video 1- Red out
2 Green Video 3- Green out
3 Blue Video 5- Blue out
4 Monitor ID - Bit 2 - N/C
5 Ground 7- Common ground
6 Red Ground 2- Red ground
7 Green Ground 4- Green ground
8 Blue Ground 6- Blue ground
9 [KEY] - N/C
10 Sync Ground - conn. all gnds together
11 Monitor ID - Bit 1 - N/C
12 Monitor ID - Bit 0 - N/C
13 Horizontal Sync 8- Hor. sync
14 Vertical Sync 9- Vert sync
15 N/C (Reserved) - N/C
I'm not sure about the Hor sweep rate but I think that its compatible.
Would an old type multisync monitor. (of the type that I scrapped
years ago) have been a better choice for this conversion? I also have
an old RGB monitor with separate BNC connectors on the back for RGB
and V and H sync. Might that also work? If anyone has some further
information on this I would be very grateful. Lenny
connections:
1- Red in
2- Red ground
3- Green in
4- Green ground
5- Blue in
6- Blue ground
8- H-sync in
9- V-sync in
10- NC
grounds are common.
Standard VGA
monitor pinout
1 Red Video
2 Green Video
3 Blue Video
5 Ground
6 Red Ground
7 Green Ground
8 Blue Ground
9 [KEY]
10 Sync Ground
13 Horizontal Sync
14 Vertical Sync
15 N/C (Reserved)
have in mind:
monitor pinout
9 [KEY] - N/C
