Malcolm \Mal\ Reynolds
If one were building such a house, would substituting simiilar sized bales of
shredded, compressed, recycled paper be viable?
Only if you want a soggy rotting mess in a few years that is harboring
the world's largest colony of silver fish.
Yes. There are companies already using scredded paper as insultation.
Straw is not used as a structural element in straw bale houses. The
structure is a framework of wood, steel or concrete that provides wind
and earthquake stability, and roof loading. The straw bales are then
stacked around and between the framework to provide insulation.
With that in mind, baled paper would be as suitable as straw for
insulation.
GeekBoy said:And most of Mexico City is sitting on bails of hay put there over 1000 years
ago.
GeekBoy said:Often referred to as "floating gardens," chinampas were stationary
artificial islands that usually measured roughly 30 by 2½ meters, although
they were sometimes longer. They were created by staking out the shallow
lake bed and then fencing in the rectangle with wattle. The fenced-off
area was then layered with mud, lake sediment, and decaying vegetation,
eventually bringing it above the level of the lake. Often trees such as
willows were planted at the corners to secure the chinampa. Chinampas were
separated by channels wide enough for a canoe to pass."
http://en.wikipedia.org/wiki/Chinampa
Yeah but where the hell are you going to find thousand year old hay bales
to build a house now?
If you go to Lake Titicaca in Peru the locals still use this system.
(Using reeds) You can stay there as a tourist. I stayed there myself
years ago. Got to watch out you don't fall through the "floor" as the
water is damned cold the lake is high up so it's cold at night.
Houses, boats, sails, everything is made out of reeds.
http://gosouthamerica.about.com/od/topdestlaketiticaca/a/floatingislands ..
htm
Re bales, Who the F*** would want to buy one if you wanted to move?
Also the rats and mice soon move in. If it gets damp, toxic fungus
spores can be released into the building. (Causes a disease known as
"farmers lung"over here.)
http://www.cdc.gov/nasd/docs/d001501-d001600/d001538/d001538.html
Can kill you!
It's the bales of straw that DO! Straw and paper is essentially the
same thing- cellulose. People have messed around with this sort of
thing over here in the UK for years/ At most it can be considered a
temporary building. Even built the ideal way ten years is the most
you can expect.
I've seen them built for example on gravel filled
trenches to keep the damp out. Also this idea of smearing mud/dung/
cement/whatever on the outside soon cracks off as the stuff moves/
The most successful one I saw was where the bales were compressed
vertically between timber ground & roof plates and clad in timber.
(Didn't keep the rats/birds out)
It was virtually a conventional
timber framed house with thick straw insulated walls. They trimmed the
excess straw off with a chain saw. So there was very little saving.
Most people into this sort of thing are some kind of eco-nut out to
prove a (strange) point.
After a while they grow out of it. Then
they build a more conventional house with good insulation.
You don't actually save much with the straw thing, particularly as it doesn't
last so long & has to be replaced. ((Boring the second time round!)
Only jungle dwellers/other primitive/poor people actually need straw
houses. But they rebuild every couple of years.
Clever the way they do it mind you...... There could be a fire hazard
problem too...
I suppose if you like the smell of straw...
but then
you're into the unknown world of paper! Do you work in an office by
any chance?
I have a conventional house with massive insulation.
