Strange SCR power supply (welder) issue
I
Ignoramus17359
I have a welder that I made from a old Hobart CyberTIG, by using aa
modern SCR firing controller by PCTI, Inc and a Cubloc microcontroller
using BASIC.
It all seems to work, but there is a bewildering issue.
Current and voltage are regulated using potentiometers. (not
microcontroller outputs, for now)
When I have current pot set to 0, and connect work and electrode leads
to make a short, the current is not 0, but is instead about 12 amps.
I verified that output voltage from the potentiometer is zero. It is
not some sort of floating ground issue for the input of the SCR firing
board -- they all share the same ground.
So.. What could it be? Why is it outputting current when it is set to
0?
Just as a side note, it sets voltage just fine and goes to zero volts
when the voltage pot is set to 0.
i
John - KD5YI
using BASIC.
0?
i
What is the maximum current?
G
Gunner
using BASIC.
0?
i
Leakage.
Cold Fusion
A blessing from Our Lady of Perpetual Motion
Gunner
"If thy pride is sorely vexed when others disparage your offering, be
as lamb's wool is to cold rain and the Gore-tex of Odin's raiment
is to gullshit in the gale, for thy angst shall vex them not at
all. Yea, they shall scorn thee all the more. Rejoice in
sharing what you have to share without expectation of adoration,
knowing that sharing your treasure does not diminish your treasure
but enriches it."
- Onni 1:33
I
Ignoramus17359
Leakage.
Cold Fusion
That's close to my list of hypotheses.
Forgot to say, I use a LEM current transducer for current feedback. It
has + and -15V inputs. I thought for a moment that perhaps if the +
and - inputs are not precise opposites, it would exhibit the observed
behavior (since there is not ground input, the zero is the middle
point between + and - input), but I know that inputs are very close,
like 15.03v and 15.01v. (according to my multimeter)
i
G
Grant Erwin
using BASIC.
0?
i
My first thought is you have an offset on your ammeter, that offset being -
tada! - about 12 amps.
GWE
I
Ignoramus17359
That's a good one, but, that's not the case. There is real
current. The needle is at zero if I have leads disconnected. When I
touch them, there are tiny sparks, and then current starts flowing.
i
Cydrome Leader
What is the problem here, aside no troublshooting skills?
you have 12 amps coming from somehwere, find out where. What's between the
power source and where you're reading 12 amps?
electricity flows in a circuit. You can can figure out where it's flowing.
I
Ignoramus17359
1 gauge wire, with work lead shorted to electrode holder.
i
Tom M
It's not going to 0 volts.
It doesn't take much voltage to get a current flow into that low impedance.
Recheck with a good DVM.
I would guess you have an offset voltage problem in your control circuit.
John
using BASIC.
0?
i
The board or the scr firing ckts may need to be balanced. IF you have
current it is coming through the scrs. The other case may be you have a
bad scr. You could put a scope on the primary side of the firing ckt but
make sure you don't get on the scr side of the firing transformer unless
you have one of the battery operated scopes designed for 600 volt
insulation or better. Even that sometimes doesn't help though, my 221
Tek scope blew up the test lead when an internal metal shield in the
scope broke free andwent across the scope lead input line inside the
scope. It was scary. It took out the 30 kw drive too.
John
Cydrome Leader
Good, now unless that wire is picking up some serious magnetic fields it
won't be generating any current.
next step. check your power source. Maybe the current is coming from
there.
Circuit = complete loop. check all the parts that complete it. Electricity
doesn't come from nowhere.
I
Ignoramus17359
Do you mean something in control circuit not referenced to the same
ground?
i
I
Ignoramus17359
Good thinking. I can try the following, supply AC power to SCRs, with
the SCR firing board not even turned on (ie disconnected from 110v).
If that 12A currrent persists, I will know that it is an SCR that is
at fault.
i
I
Ignoramus17359
there.
Yea, that's where it is coming from, the power source!
I am sure that it is coming from the SCR rectifier, there is nowhere
else it could come from, the question is why.
So far I see the following possibilities:
1) SCR firing board is getting wrong control signal inputs (ie, wrong
desired voltage signal). Maybe due to incorrect grounding.
2) SCR firing board gets bad feedback signals from the current sensor
3) SCRs are bad and "leak electricity"
Case 1 can be tested by forcibly connecting the "desired current"
input of the SCR firing board to the ground (as well as the negative
end of where the potentiometer is to be wired to the SCR firing
board). If current disappears, I know that I have bad input.
Case 2 can be tested by supplying 4 volts to the current sensor input
of the SCR firing board (that means that the board is led to believe
that the current is too high, as my max current setting is much
lower). So, if it is any good, it should go as low as possible.
Case 3 is easy to test for -- there should be no current when 3 phase
AC is applied to the input of SCR rectifier and SCR firing board is
turned off (ie it is not supplied with 110V power to run at all). If
current persists, we know that I have one or more bad SCRs.
Any more thoughts?
i
Paul E. Schoen
i
Most SCRs have some sort of snubber connected across them to limit dV/dT
turn-on. Usually, they draw only 100 mA or less. If you have an output
transformer with a high ratio, it would cause higher output current, but
your 12 A would mean a ratio of 100:1 or so. It would be helpful to look at
the output waveform to see if there may be any high frequency spikes, which
could be caused by transients in the supply line. They would be conducted
by the snubbers and cause possibly high currents.
Paul
W
Wild Bill
You haven't mentioned that you have measured the SCRs Gate terminal
voltages, and what part of the circuit you're using for the zero
reference.
As you most likely know, the SCRs shouldn't be conducting when there is
no voltage potential on the Gate terminals.
I would suspect that the Gate terminal signals are referenced
incorrectly, and not being reduced to zero volts.
If your DVM isn't indicating that signals are present at the Gate
terminals, you would need to investigate a safe method of utilizing an
oscilloscope.
Many electrical devices utilize several separate, different circuit
ground points. Digital circuits ground is separate from power devices
ground, and the separate grounds will be isolated from each other, and
often isolated from earth ground.
I would anticipate a sophisticated welder might possibly have 4 or more
grounds.. digital/timing, analog/control, power/output, and
earth/safety ground.
You mention that the Voltage pot when set to zero, yields zero volts
output.
I don't think you were implying that you're measuring 12 amps at zero
volts, but your explanation wasn't clear about that.
WB
Mark Rand
using BASIC.
0?
i
If the voltage pot is set above zero and the problem is that you are not
getting zero when the current pot is now set to zero, then I would suggest an
offset in the current sensor output. If it has an offset control then adjust
it. If not, then another op amp, twiddle pot and couple of resistors are
called for to give you that adjustable offset. All this assuming that you
aren't getting current when you disconnect the SCR gate leads :)
Mark Rand
RTFM
I
Ignoramus27242
Not the case. Grounding desired current input did not change anything.
did not have time to test
also not the case
I
Ignoramus27242
["Followup-To:" header set to rec.crafts.metalworking.]
I am now tending to think that perhaps this is simply a deficiency of
my SCR firing system, and that perhaps I should just "learn to live
with it".
i
